dominique23
Jan 7, 2003 10:04 AM UTC
using ST7F521 with 3.3V devices
Posted on January 07, 2003 at 11:04
dominique23
Jan 7, 2003 4:45 AM UTC
Posted on January 07, 2003 at 05:45
I would like to use ST7F521 with a 3.3V Fpga, I have been said that the 2 additionnal port (G and H) of the 80 pins version are TTL whereas the port in the 64pin version are all in true cmos level (3.5v min for H level).
I want to have confirmation of this information.
Thanks.
sjo
Jan 7, 2003 7:16 AM UTC
Posted on January 07, 2003 at 08:16
The additional ports are TTL but your main concern would be that the newer revision silicon (datasheet v1.6) supports only 3.8-5.5v operating conditions.
Spen
dominique23
Jan 7, 2003 8:41 AM UTC
Posted on January 07, 2003 at 09:41
thanks you very much but where can I find this version of the datasheet, I don't find it on this site...
simms
should be accessible from this site by selecting ST72521 product from the home page
try this link too, if it helps...
http://us.st.com/stonline/books/pdf/docs/7601.pdf
