AAli.1
Sep 9, 2019 2:47 PM UTC
Using eDesignSuite, design a Power Supply having 1 isolated output and 2 non-isolated outputs
I am trying to design a power supply using eDesignSuite, having universal input from85~265VAC/50Hz and having 1 isolated output 10V@15mA and two non-isolated outputs 15V@75mA and 3.3V@50mA (flyback converter). But I am unable to design both isolated and non-isolated outputs in eDesignSuite.
Could you please help me in this regard?
Best Regards,
Anayat
Patrizia BELLITTO
Sep 9, 2019 3:18 PM UTC
eDesignSuite allows you to design AC/DC isolated and not isolated flyback converters with VIPerx6 and VIPerx1 ICS.
For VIPerx6 solutions, you can even specify more than one output.
Best regards,
Patrizia
Patrizia BELLITTO
Sep 9, 2019 2:54 PM UTC
sorry but this kind of solution cannot be directly designed through eDesignSuite.
Best regards,
Patrizia
AAli.1
AAli.1Author
Sep 9, 2019 2:57 PM UTC
Hi, Ok. Thanks for your reply. What is the best solution to design the required power supply using ST components? Best Regards, Anayat Anayat Ali Electronics Engineer [Logo] a.ali@torin-sifan.com Office: +44 (0) 1793 524291 ext 228 Fax: +44 (0) 1793 486570 www.torin-sifan.com [cid:image5917e8.BMP@1789f0bd.418a2ef3] [cid:image80a8be.PNG@75b4a223.46940378]<> Torin-Sifan Limited Registered in England No 4569050 Registered Office: Fleming Way, Crawley, West Sussex, RH10 9YX This e mail and its attachments may be confidential and are intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient you must take no action based on it, nor must you copy it to anyone, and you must delete it immediately. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Torin Sifan Limited or any of its associated companies. This e mail does not constitute a commitment by Torin Sifan Limited or any of its associated companies. Please contact the author if you believe that you have received this email in error.
Patrizia BELLITTO
Sep 9, 2019 3:11 PM UTC
You can surely use VIPerx6 or VIPerx1 family ICs.
AAli.1
AAli.1Author
Sep 9, 2019 3:14 PM UTC
There is any design tool to do this? Or any other helpful data? Best Regards, Anayat Anayat Ali Electronics Engineer [Logo] a.ali@torin-sifan.com Office: +44 (0) 1793 524291 ext 228 Fax: +44 (0) 1793 486570 www.torin-sifan.com [cid:imageb54cf9.BMP@f9fe87e0.47996e5c] [cid:image58e39a.PNG@8b54b1fc.4caf22bb]<> Torin-Sifan Limited Registered in England No 4569050 Registered Office: Fleming Way, Crawley, West Sussex, RH10 9YX This e mail and its attachments may be confidential and are intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient you must take no action based on it, nor must you copy it to anyone, and you must delete it immediately. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Torin Sifan Limited or any of its associated companies. This e mail does not constitute a commitment by Torin Sifan Limited or any of its associated companies. Please contact the author if you believe that you have received this email in error.
Patrizia BELLITTO
Best regards,
Patrizia
AAli.1
AAli.1Author
Sep 9, 2019 3:22 PM UTC
Well but it will be either isolated or non-isolated design with more than one output? Best Regards, Anayat Anayat Ali Electronics Engineer [Logo] a.ali@torin-sifan.com Office: +44 (0) 1793 524291 ext 228 Fax: +44 (0) 1793 486570 www.torin-sifan.com [cid:imageaf64f2.BMP@2821660b.4791d4b3] [cid:image73abf1.PNG@242c0f91.4492f043]<> Torin-Sifan Limited Registered in England No 4569050 Registered Office: Fleming Way, Crawley, West Sussex, RH10 9YX This e mail and its attachments may be confidential and are intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient you must take no action based on it, nor must you copy it to anyone, and you must delete it immediately. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Torin Sifan Limited or any of its associated companies. This e mail does not constitute a commitment by Torin Sifan Limited or any of its associated companies. Please contact the author if you believe that you have received this email in error.
Patrizia BELLITTO
Sep 9, 2019 3:32 PM UTC
Yes, either isolated or non isolated designs
AAli.1
AAli.1Author
Sep 9, 2019 3:33 PM UTC
Thank You So Much Best Regards, Anayat Anayat Ali Electronics Engineer [Logo] a.ali@torin-sifan.com Office: +44 (0) 1793 524291 ext 228 Fax: +44 (0) 1793 486570 www.torin-sifan.com [cid:imageabec6a.BMP@76cac0c9.4c85a3af] [cid:image427a09.PNG@3b592d6c.40b870c6]<> Torin-Sifan Limited Registered in England No 4569050 Registered Office: Fleming Way, Crawley, West Sussex, RH10 9YX This e mail and its attachments may be confidential and are intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient you must take no action based on it, nor must you copy it to anyone, and you must delete it immediately. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Torin Sifan Limited or any of its associated companies. This e mail does not constitute a commitment by Torin Sifan Limited or any of its associated companies. Please contact the author if you believe that you have received this email in error.
Patrizia BELLITTO
Sep 9, 2019 3:36 PM UTC
You're welcome.
Best regards,
Patrizia
AAli.1
AAli.1Author
Sep 10, 2019 9:08 AM UTC
Hi, I am trying to use eDesignSuite, but when I click on the Start Design, the page gives me ‘502 Proxy Error’. Could you please help me that what is the problem with server? Best Regards, Anayat Anayat Ali Electronics Engineer [Logo] a.ali@torin-sifan.com Office: +44 (0) 1793 524291 ext 228 Fax: +44 (0) 1793 486570 www.torin-sifan.com [cid:imagefaf501.BMP@4db5742d.47854b38] [cid:image1ae665.PNG@e66425fb.47b76e41]<> Torin-Sifan Limited Registered in England No 4569050 Registered Office: Fleming Way, Crawley, West Sussex, RH10 9YX This e mail and its attachments may be confidential and are intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient you must take no action based on it, nor must you copy it to anyone, and you must delete it immediately. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Torin Sifan Limited or any of its associated companies. This e mail does not constitute a commitment by Torin Sifan Limited or any of its associated companies. Please contact the author if you believe that you have received this email in error.
Patrizia BELLITTO
Sep 10, 2019 9:12 AM UTC
could you please try to SIGN IN before starting the design? You will find the SIGN IN button in the upper right corner.
Regards,
Patrizia
AAli.1
AAli.1Author
Sep 10, 2019 9:37 AM UTC
Hi, I did it many time but it was giving same error…. but now it’s OK. Thank You Best Regards, Anayat Anayat Ali Electronics Engineer [Logo] a.ali@torin-sifan.com Office: +44 (0) 1793 524291 ext 228 Fax: +44 (0) 1793 486570 www.torin-sifan.com [cid:imagec5bfc6.BMP@39dc75ba.40afb805] [cid:image00e768.PNG@5a275c89.49a15748]<> Torin-Sifan Limited Registered in England No 4569050 Registered Office: Fleming Way, Crawley, West Sussex, RH10 9YX This e mail and its attachments may be confidential and are intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient you must take no action based on it, nor must you copy it to anyone, and you must delete it immediately. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Torin Sifan Limited or any of its associated companies. This e mail does not constitute a commitment by Torin Sifan Limited or any of its associated companies. Please contact the author if you believe that you have received this email in error.
