Nimit Vachhani
USE SWIM pin in STM8S105 as gpio
Greetings Friends,
I have STM8S Discovery Board with STM8S105 micro controller. I want to use SWIM pin as general purpose IO and also want to use it to upload the code.
Is there any possibilities ?
    Philipp Krause
    Senior II
    February 22, 2020
    Using the SWIM data pin as I/O should just work normally as expected.
    It only gets more complicated when you also want to use the reset pin as I/O (common on 8-pin devices, but AFAIK not possible on the larger STM8 devices).
