yak8027au
Feb 22, 2007 12:18 PM UTC
Use OCMPB to generate PWM Signal
Posted on February 22, 2007 at 13:18
yak8027au
yak8027auAuthor
Feb 6, 2007 2:17 AM UTC
Posted on February 06, 2007 at 03:17
I wanted to generate signal using PWM mode. However, the existing OCMPA pins are already occupied for other purposes. How can I use other pins like OCMPB to generate a PWM output?
kaouther
When timer is configured in PWM mode, the PWM signal will be generated on OCMPA pins. It would be better to use the OCMPB pins for other purposes as it is already available and not used in PWM mode and use the dedicated pin the OCMPA for the PWM signal.
