reg007
Mar 1, 2006 11:25 AM UTC
USB Reset in Bulk Example
Posted on March 01, 2006 at 12:25
reg007
reg007Author
Hi again.
I have some Probs finding the Reset funktion for the USB-Bulk example.
I found the Reset funktion call in the usb_istr.c, but i can not find the implementation.
The main problem is: I can open my USB-Device one time, and everything works fine. After closing the Pipes and the device i am trying to open it again, but now i am not able to bind the Pipes. I wonder if this problem can be solved by sending an reset-request to the device.
If anyone has a better way to solve the problem, and to be able to bind the pipes several times.... :))
I'm thankful for every hint.
regards
re-G
