michel239955_st
Jun 13, 2008 6:36 PM UTC
USB implementation help please
Posted on June 13, 2008 at 20:36
rgreenthal
May 17, 2011 7:53 AM UTC
Posted on May 17, 2011 at 09:53
Don't forget if you get a HW Reset that isn't from the Power on Reset you need to
// A system reset does not reset the USB registers.
_SetCNTR(0x0003);
_SetISTR(0x0000);
_SetDADDR(0x0000);
_SetBTABLE(0x0000);
michel239955_st
Hi, I have a sofware running in STR9 (STR912FW44XB). I need to install a command system via usb. The mcu receive ascii command and generate action acording to them). I download the DFU_bootloader but i still don't know how to start. Can someone resume me the step to get it work. An example will be also greatly apreciate.
Thank you for your help
Michel
