CWei .1
Jan 9, 2026 2:09 AM UTC
USB-C PD: STUSB4500 FTP_KEY changable?
Hello ST
I would like to ask about is it possible to change the STUSB4500 FTP_KEY default values through SMBUS interface? If its possible, could you suggest the appropriate step to do so?
Didier HERROUIN
Didier HERROUINBest answer
Jan 12, 2026 1:24 PM UTC
Dear CWei.1,
The procedure to write/read the registers is fixed, including the FTP_KEY values.
Didier HERROUIN
Jan 9, 2026 10:07 AM UTC
Dear CWei.1,
I am not sure to understand your request.
Actually, when you need to access the STUSB4500 registers, as a first step, you must write the customer access key into the FTP_KEY register using the I2C bus.
This procedure is described in the document attached. Does it answer your request ?
CWei .1
CWei .1Author
Jan 10, 2026 1:19 AM UTC
Hello
I have reviewed the document. Could you please clarify whether the default values of FTP_KEY are fixed, or if they can be modified and configured to user-defined values?
Didier HERROUIN
Dear CWei.1,
