wdcai
May 20, 2004 9:06 PM UTC
upsd33xx spi interface problem
Posted on May 20, 2004 at 23:06
wdcai
wdcaiAuthor
May 17, 2011 10:00 AM UTC
Posted on May 17, 2011 at 12:00
Hi,All
There is a host spi controller in upsd33xx series,but only one spi slave chip select signal is provided, how can I connect another spi device? I can use cd4051 cmos swicth to do this, but I want to know whethwer GPIO pins such like P1 port can be used as chip select signals?
Thanks!
wdcai
wdcaiAuthor
that is to say those signal spicclk,spirxd,spitxd will run normally in SPI interrupt mode using GPIO as chipselect signals of other spi slave device! is it OK?
sjo
just clear SSEL bit to disable the CS line, then you can use GPIO to manually set the CS line of your choice before loading the data.
sjo
