epassoni9
Oct 26, 2009 4:31 AM UTC
unexpected jump
Posted on October 26, 2009 at 05:31
unexpected jump
    brazov2
    May 17, 2011 1:05 PM UTC
    Posted on May 17, 2011 at 15:05
    if the micro decodes and illegal opcode, you'll get an illegal opcode reset. Check the status register of the reset controller to see reset source.
    Coluber
    epassoni9
    epassoni9Author
    What happens if the program counter goes to a location loaded with 0x00?
    (for example,I know that if the location contains a ''nop'' op-code it goes to the next location.)
    Since the 0x00 is not an op-code,what happens ? thanks! :)
    Spectre
    p.s. I have already read the an on the emc interferences
    epassoni9
    epassoni9Author
    Dear brazov2,
    I have solved my issue.
    (I was not sure that 0x00 is an illegal opcode.)
    regards
    Spectre :)
    brazov2
    Hi spectre,
    can you better specify the problem you want to solve? If you want to remove illegal byte 00h from your code and you have a block of all zeros, perhaps you can simply fill it with TRAP opcode (83h) to keep a better control of unexpected jumps instead of getting an illegal opcode reset.
    coluber
    epassoni9
    epassoni9Author
    Dear brazov2,
    I didn't understand your answer.I know that I can check the reset source but I have mentioned the emc application note only because I have read on it the illegal op-codes list.
    I agree with you that if the program counter pointer goes on a illegal op-code I'll get an mcu reset.But I'm interested about a block filled with 0x00.
    regards
    Spectre
    [ This message was edited by: spectre on 23-10-2009 14:19 ]
