babidesai123
Apr 14, 2003 11:53 AM UTC
unable to read the flash memory contents after programming
Posted on April 14, 2003 at 13:53
babidesai123
May 17, 2011 9:53 AM UTC
Posted on May 17, 2011 at 11:53
I am trying to read the flash memory contents after programming the upsd323X using JTAG flash link programmer.
I tried to read using ST conventional programmer--upload (one of the option in PSD SOFT EXPRESS)
note: the hardware set up is showing ''PSD PRO''
With this steps :
i am getting an error message
'' upsd 3234 is not currently supported by psd pro''
we have written the code for IAP in C.. but not in a position to test the same ...since we want to know at which location we are wriiting or erasing + how the interrupt remapping is done
So can you please help us ....
We have very little time to develop the code...so reply soon...
purvi
joseph2399
The uPSD products CANNOT be programmed or read using a conventional programmer. The uPSD ONLY works with JTAG programming! There are several programmers that support JTAG, please check out the www.st.com/micropsd web site for info
on JTAG programmers.
babidesai123
Thanks alot...
yu-jun
Purvi:
I have not time to resolve you question because I have not device to do it and I am not PSM Group. I am ST MCU APCC. I have send you question to PSM Group.
So you can send your detailed question to
mailto:jacky.jia@st.com
