selaslan
Oct 13, 2009 4:49 PM UTC
Unable To Halt ARM Core, STR710
Posted on October 13, 2009 at 18:49
selaslan
selaslanAuthor
Sep 4, 2009 12:41 PM UTC
Posted on September 04, 2009 at 14:41
I'm developing a network door access controller based on STR710FZ2
I have designed my own PCB and manufactured 5 samples of this board.
When I want to start to run my code, I always receive ''Unable To Halt ARM Core'' message,
I'm using IAR V5.11 compiler
I have downloaded latest version of J-Link drivers from Segger.
I have tried to reset via J-Link Commander and J-Link Flash utility.
But same result.
I have attached some screenshots related to my tryouts
Can you help me how can overcpme from this issue
Selahattin Aslan
selaslan@gmail.com
________________
Attachments :
IAR_Compiler_-_Error.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtJe&d=%2Fa%2F0X0000000aLW%2FSJyizZHSFZ_FhIRmeJsE4NcKGt5tGT4rEmYnjAyfbnI&asPdf=false
JLink_Commander_-__Error.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtSB&d=%2Fa%2F0X0000000aQD%2FJIH3zIU3ztT3z1wPn64AvfVaBXDzEicrIw3fukKWwOY&asPdf=false
JLink_Flash_-__Error.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtRT&d=%2Fa%2F0X0000000aQ6%2Ftq5pj0ryf2S92rp4OQ0c9GX5oj8EIUMj4GgKbD2.SgU&asPdf=false
tomas23
Check the reference schematics of ST evaluation boards for the complete JTAG connection. The nJTRST and nRST signals have to be well implemented, too.
If you already have some code in FLASH, try to change boot settings to RAM and try to connect again.
Otherwise attach your schematics.
[ This message was edited by: edison on 13-10-2009 22:20 ]
