raunaque
Oct 27, 2004 9:25 AM UTC
unable to burn firmware on the ST7 device
Posted on October 27, 2004 at 11:25
raunaque
raunaqueAuthor
Oct 26, 2004 7:11 AM UTC
Posted on October 26, 2004 at 09:11
Hi
i am trying to burn the firmware on the ST7 device . i go to tools-> programm and check the erase option , write option , verify option and run option on ST7 Debug . It gives the output successfully written but when i try to see the descriptor of the device using a software i get the value 0x0 .The device shows that it is connected. Can anybody help me out.
thanks in advance
alain2399
could you give more information on your context:
OS version, ST7 device used, version of STVD (go to about window), harware used for programming.
This would allow us to try to reproduce the issue you have.
Regards,
