bcn_yang
Dec 10, 2010 6:40 PM UTC
UBC Option Byte does not work correctly
Posted on December 10, 2010 at 19:40
    brazov22
    May 17, 2011 1:11 PM UTC
    Posted on May 17, 2011 at 15:11
    how did you set UBC? If you programmed optin bytes from your firmware (C or ASM code) then you need to apply a reset to make them effective. If you used STVP to set UBC, a reset is applied by the debugger automatically to make option bytes to be loaded. I suggest you to set all option bytes using STVP.
