dipti
Jun 23, 2010 6:47 AM UTC
UART1 example with reference to chm file(stm8s_fwlib_um)
Posted on June 23, 2010 at 08:47
    mozra272
    May 17, 2011 1:09 PM UTC
    Posted on May 17, 2011 at 15:09
    Hi ,
    Regarding the reference manual the BRR values are evaluated using fMaster = 24Mhz and in your case you have fMaster = 16MHz.
    Can you please check another hypertherminal tool (try Hercules.exe) and your hardware connection.
    You can download Hercules.exe from this link:
    http://hercules-setup.hw-group-s-r-o.qarchive.org/
    If the Hypertherminal is not correctly configured you should receive data but is not correct.
    The expected data ''HyperTerminal Interrupt: UART1-Hyperterminal communication using Interrupt''
    Best Regards
    mozra
