cfortier
Feb 26, 2007 9:37 AM UTC
UART + ETHERNET
Posted on February 26, 2007 at 10:37
UART + ETHERNET
cfortier
cfortierAuthor
May 17, 2011 7:31 AM UTC
Posted on May 17, 2011 at 09:31
Hi guys,
I'm using the STR912-SK from IAR with NexGen IP stack. I'm trying to enable Ethernet communication with UART at the same time. But when i enable the UART i'm unable to communication with the Ethernet.
I will investigate today and will update my problem soon. But i'm just posting this to see if someone had the same problem.
Have a nice day :D
Constantin
cfortier
cfortierAuthor
I have a project using UART1, UART2 and ENET by interrupt and it's working fine.
Is your project fine ?
tong
I am looking at a project inwhich I have to do the same.
Have you resolve this problem?
alain239955_st
I got some thing similar .
Quiete Loaded Ethernet on IRQ work fine alone,
Full stream on UART_2 at 250000 Baud work fine alone
But if I start UART Stream while Ethernet is receiving ... Ethernet IRQ is no more trigged ... ?
