jones2
Feb 23, 2004 1:21 AM UTC
uart
Posted on February 23, 2004 at 02:21
uart
hanan54
May 17, 2011 9:58 AM UTC
Posted on May 17, 2011 at 11:58
hi
Yes you can use a different baudrate for each uart.
Uart0 use timer2 and uart1 will use timer1.
To select timer2 for uart0 set RCLK = 1 ,TCLK= 1 in T2CON
To select timer1 for uart1 set RCLK1 = 0 ,TCLK1= 0 in PCON
see T2CON,PCON Register detail in the data sheet
hanan
[ This message was edited by: hanan54 on 23-02-2004 06:53 ]
jones2
jones2Author
can I use a different baudrate for each uart.
I'm currently using timer2 as baudrate generator.
Thanks.
