info37
Oct 13, 2009 4:25 PM UTC
Tracing Undefined_Handler origen.
Posted on October 13, 2009 at 18:25
tomas23
May 17, 2011 7:58 AM UTC
Posted on May 17, 2011 at 09:58
Hi Mark, create a handler for the Undefined, eg. B Undefined_Handler to stop there. Then place a breakpoint there and when the code stops, read the LR, it should point to PC+4 or PC+8. Then look for this address in the disassembly window of IAR.
Pls read the ARM Architecture Reference Manual or ARM966 Technical Reference Manual on www.arm.com, section about exceptions.
info37
info37Author
Hi. Is it possible to locate in the source code what sentence causes a jump to the Undefined_Handler ? I'm using IAR's workbench.
Thank you.
Mark
