tran
Aug 31, 2009 12:25 PM UTC
Touch sensing library
Posted on August 31, 2009 at 14:25
    tran
    tranAuthor
    May 17, 2011 1:04 PM UTC
    Posted on May 17, 2011 at 15:04
    Hello all,
    Where can i find the library for Touch Sensing Application, pls?
    I can't find it in this site.
    Thx you very much,
    Jaroslav BECKA
    Aug 29, 2017 1:32 PM UTC
    Posted on August 29, 2017 at 13:32
    the touch sensing library is delivered within STM32Cube embedded software packages.
    As an example, in case of STM32F0, the package is called STM32CubeF0.
    You can download it here: ,
    http://www.st.com/content/st_com/en/search.html ♯ q=stm32cube-t=keywords-page=1
    You will find the touch sensing library under following path: ...\STM32Cube_FW_F0_V1.8.0\Middlewares\ST\STM32_TouchSensing_Library
    The STM32CubeMX tool is also capable to ,download the embedded software package ,and on top of that it is able to automatically check for new releases.
    gates.nathan
    Dec 17, 2017 7:28 PM UTC
    Posted on December 17, 2017 at 19:28
    Hi @
    BECKA.Jaroslav.002
    could you please explain the process for manually included the touch sensing lib into a cubemx generated project.
    I've been trying for a while using the f042 and have had no success.
    thanks
