BTsoi.1
TMMDB3 part no. have \K and /HF what is the differences? is this DIAC item is polarize?
We cannot find any info about the \K and /HF
When we try to use the /HF, which looks like it is polarized, but in TMMDB3 datasheet, it never mentioned. So we want to clarify.
Peter BENSCH
Welcome, @BTsoi.1​, to the community!
there is no technical difference, the suffixes are an internal identifier and only designate the place of manufacture that is not relevant for the function.
Good luck!
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
BTsoi.1
BTsoi.1Author
Hello Peter
Then how about the polarise issue?
Is this item are polarise ? means it have positive side and negative side?
Brian
Peter BENSCH
No, DIACs are bidirectional, as you can also see from the datasheet, fig. 1.
The TMMDB3 is packaged in MINIMELF, so it might look like a unidirectional diode, but is symmetrical and therefore bidirectional.
/Peter
