twb
Mar 10, 2005 9:10 AM UTC
timer eample
Posted on March 10, 2005 at 10:10
timer eample
twb
twbAuthor
Mar 8, 2005 1:35 PM UTC
Posted on March 08, 2005 at 14:35
Hi I'am trying to run the timer example TIM/Music on a STR710 EVAL board in order to get the timers to work, but I'm running into a number of problems.
The latest error message I get is:
Error: L6218E: Undefined symbol Image$$ZI$$Limit (referred from sys_stackheap.o).
Does anybody know what this means and how to overcome the problem?
I've included all the project files in the zip file attached here.
________________
Attachments :
cycle_count.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1ND&d=%2Fa%2F0X0000000bm9%2FXqWbsCCeBiZKHX99CHOkgnn1gswBzIF7ujYea8nht6A&asPdf=false
marcus23
Mar 8, 2005 5:42 PM UTC
Posted on March 08, 2005 at 18:42
Hi Spiff,
I think you just need to add the file ''retarget.c'' from ST-Software-Library to your projects (in RVDK: Project => Add Files to Project)
hichem2
Mar 9, 2005 3:42 AM UTC
Posted on March 09, 2005 at 04:42
Hello Spiff,
You find attached your project, it work perfectly on my desk
only I included the retarget.c (you are right mweigelt ), but you have also to comment out the 2 following lines of code in STR71x_conf.h.
//#define USE_SERIAL_PORT
//#define USE_UART0
With regards,
Hich. :p
________________
Attachments :
cycle_count.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1N8&d=%2Fa%2F0X0000000bm6%2FcIrGT5pX0v78tRTOeOuTvzkQr5rxYw0O2GwTdlXl1L0&asPdf=false
twb
twbAuthor
Mar 9, 2005 4:51 AM UTC
Posted on March 09, 2005 at 05:51
It works, Thanks! :D :D
By the way, do you know where to find the latest version of all the library/example files. It seems like every time I get a hold of a new piece of code there are minor differences, so it coul dbe graet to have a (nearly) error free version of the files.
hichem2
Mar 9, 2005 8:31 AM UTC
Posted on March 09, 2005 at 09:31
Hello Spiff,
The latest version of all the library/example files is ready and it will be published on STMCU soon (within one week).
For any urgency, I can send you the last version of the package.
PS: You can subscribe in the stmcu site, like this you will be automatically informed when the new version is published.
With regards,
Hich. :p
twb
twbAuthor
Hi Hich,
I would certainly apreciate a new version of the lib/example files if you have them. Can you attach them here?
