kobihaun
kobihaunAuthor
May 17, 2011 9:53 AM UTC
Posted on May 17, 2011 at 11:53
Hi Every body
How can I calculate the value for the buffers TH0 and TL0 in order to have interrupt every 1ms.
Thank you very much
Hayun
joseph2399
Timer0_count = 0 - (osc/(12*timer0_period)) - 17
so if your osc freq = 36MHz, then Timer0_count = 0xf459,
if, osc freq = 40MHz, then Timer0_count = 0xf30c
Load the high byte of timer0_count to TH0, and the low byte to TL0.
