krzysztof239955_st
Oct 2, 2009 7:13 AM UTC
The problem with calculations on types float with Cosmic compiler
Posted on October 02, 2009 at 09:13
    krzysztof239955_st
    May 17, 2011 1:04 PM UTC
    Posted on May 17, 2011 at 15:04
    Why variable wsp_kal not have after the calculations of the correct value 0.000038?
    Example:
    float masa_kal,dzal_kal1,dzal_kal2,dzal_kal,wsp_kal;
    masa_kal = (float)(mas_kal[i+1]-mas_kal[i]); // correct 5
    dzal_kal1 = (float)kal_ram.dz_kal[i+1]; // correct 329602
    dzal_kal2 = (float)kal_ram.dz_kal[i]; // correct 198530
    dzal_kal = (float)(dzal_kal1-dzal_kal2); // correct 131072
    wsp_kal = (float)(masa_kal/dzal_kal); // incorrect 0
    krzysztof239955_st
    The setting Display Item from Decimal on Standard in debuger solved the problem.
    Best regards
    krzysztof.skoczek
    krzysztof239955_st
    I use STVD 4.1.2 and the compiler Cosmic CxSTM8 4.3.1 with optimizations: Minimize code size (+compact). Declaration: float masa_kal,dzal_kal1,dzal_kal2,dzal_kal,wsp_kal=0.0; - not bring the improvement.
    Best regards
    mozra27
    What is the compiler used in your application and what is the optimization level?
    Please check with the following declaration:
    float masa_kal,dzal_kal1,dzal_kal2,dzal_kal,wsp_kal = 0.0;
    mozra
