KSamn.1
Dec 16, 2022 4:29 AM UTC
Teseo-LIV3F module is not sending out any message throught
I'm using AEK-COM-GNSST31 to valuate Teseo-LIV3F. Firstly, it worked so well throught the default setting values. My problem is after i set command to change uart baurate from 9600 to 38400 there is no output signal from uart.
below are commands i set:
1. $PSTMCFGPORT,0,0,1,38400
  got return $PSTMCFGPORTOK
2. $PSTMSAVEPAR
  got return $PSTMSAVEPAROK
than Power OFF -> Power ON
The result is i could not any output signal from uart. but PSS signal is still normally work.
I try restore such below:
1. Restore factory setting  $PSTMRESTOREPAR
2. Reset           $PSTMSRR
but it not working( No respose from Uart)
Did my command are wrong?
Why Teseo-LIV3F stop sending output messages via Uart?
Thank you in advance for help!!
    KCerq.1
    May 2, 2023 7:32 PM UTC
    From my point of view, you did nothing wrong. Have you tried to change the baud rate on your PC serial terminal emulator? On TESEO-SUITE, open the configuration session menu and select "settings" to change the UART baud rate to the desired bps on this software.
    May 2, 2023 8:52 PM UTC
    Did you check pin with a scope?
