TDA2030A IC AUDIO AMPLIFIER MODULE
Hi, everyone
This TDA2030A amplifier module use dual power supply ±12 Voltage
See attached image file
Peter BENSCH
Peter BENSCHBest answer
Firstly, please note that the TDA2030A has been discontinued many, many years ago and has not been manufactured by STMicroelectronics since then.
Your photo shows an Asian product that uses the TDA2030A in single supply configuration.
/Peter
RobK1
And your question is?
SREYASAuthor
This board use dual power supply voltage
RobK1
Ah, so you are asking if this board uses dual power supply, correct?
Looks a lot like the modules you can get for almost nothing on Aliexpress: TDA2030 Module Voeding TDA2030 Audioversterker Board Module TDA2030A 6-12V Enkel - AliExpress
These have a single-ended supply.
SREYASAuthor
TDA2030A AMPLIFIER MODULE USE  DUAL POWER SUPPLY
Peter BENSCH
/Peter
SREYASAuthor
Ok
