seecure
system stuck-in crtsx
  • March 22, 2004
  • 5 replies
  • 927 views
Posted on March 22, 2004 at 20:34
seecure
seecureAuthor
Posted on March 11, 2004 at 14:26
hello forum!
platform: ST72F5R9T , cosmic, indart-STX
does any one can explain me why software as already work properly
sudenlly stuck-in:
rsp
ld a,(__idesc__+4,x) ; store
ld c_y+1,a ; vector
dbcl:
ld a,[c_x.w] ; transfer
ld [c_y.w],a ; byte
inc c_y+1 ; increment
nulljrne dok ; destination
inc c_y ; address
dok:
inc c_x+1 ; increment
jrne sok ; source
inc c_x ; address
sok:
and it can't recover anymore
any idia
when I program it via DataBlze it runs!!!
atz
nciot
March 15, 2004
Posted on March 15, 2004 at 05:25
Hi Atz,
when you build your code, does it give any error?
Nicola
seecure
seecureAuthor
Posted on March 19, 2004 at 07:21
Hi Nicola,
No there is no error! and I usally save the last project that
allready works good.Also the last project which has been worked properly,stuck in that point.
Anyway, the day after it recovered. today it hapands again.
I work with the datablaze programmer and waiting to sunday may be it will recoverd again.
it is very strange thing!
atz
jatin
March 22, 2004
Posted on March 22, 2004 at 02:06
Could you monitor your resewt pin to check whether there is an unwanted reset after you start running your code?
seecure
seecureAuthor
Hi Jatin
The software is interrupt event driven, so the way I could debug the
software is to put a TRAP in my code and then use breakpoint.
sometime it dosen't break and the BP. then I reset the system, in that
point the crtsx.s is stuck!.
I found out that 'remove all breakpoint' then reset recover the debugger and enable me continue work in debug mode.
do you have any explanation ?
atz
