sbencke3
Dec 12, 2003 7:16 AM UTC
Switching Block Memory
Posted on December 12, 2003 at 08:16
danielh1
May 17, 2011 9:57 AM UTC
Posted on May 17, 2011 at 11:57
Are you sure to are still at page 0 when you try to come back?
sbencke3
sbencke3Author
Hello!
I'm having some problems to switch from secondary to primary flash !
My Memory Map (start):
rs0: 2000~3fff
csiop: 200~2ff
FS0: 0000~7FFF PAGE0 code space
FS1: 0000~7FFF PAGE 1 code space
FS2: 0000~7FFF PAGE 2 code space
CSBOOT0: 0000~1FFF data space
CSBOOT1: 2000~3FFF data space
CSBOOT2: 4000~5FFF data space
CSBOOT3: 6000~7FFF data space
When I execute the command:
PSD8xx_reg.VM = 0X12;
I jump from the primary Flash to the secondary, where i have the same firmware, but I can’t come back using the command:
PSD8xx_reg.VM = 0X0C;
Please, what I'm doing wrong? Somebody can help me, please?
sbencke3
sbencke3Author
No, I'm not sure.
I know that my program doesn't work when I try to come back to the primary flash, and when I jump from de primary flash to the secondary its works just if both programs are very similar.
I don’t find anything in the datasheet, I thing that when I change from one block to another the program counter don’t change to the beginning of the program. Is it correct? How can I do this?
Can you help me, please ?
