leoren_tm
Oct 20, 2010 7:10 AM UTC
SWIM OFF mode.
Posted on October 20, 2010 at 09:10
SWIM OFF mode.
    leoren_tm
    leoren_tmAuthor
    May 17, 2011 1:11 PM UTC
    Posted on May 17, 2011 at 15:11
    CFG->GCR =0x00; //----work, typo error at the datasheet?
    leoren_tm
    leoren_tmAuthor
    Hi.
    I got my Buzzer working, and GPIO on SWIM pin, with and without changing  SW bit
    in that CFG->GCR =0x00; and CFG->GCR =0x01; will work., but observe on scope, CFG->GCR =0x01; take long to have a stable output, compared to CFG->GCR =0x00;
    but using as GPIO, both work.
    leo
    lowpowermcu
    Hi leo,
    How are you checking this ?
    Herzlich,
    MCU Lüfter
    leoren_tm
    leoren_tmAuthor
    Hi MCU Lüfter
       CFG->GCR =0x00;
    using that value work, as I can use the port like toggle. but im not sure if the AL bit will be affected and also im still having problem using beep.
    I think ill need some official statement on the SWIM bit.
    Also one of my unit SWIM disable, as like could not use it anymore. Reference manual says, at start up SWIM will be ON, therefore I can still use SWIM with POR reset.
    later ill try reading SWIM bit in a normal condition.......
    leo
    leoren_tm
    leoren_tmAuthor
    Hi MCU Lüfter
    on standalone mode, I mean on my custom PCB. Oh I never even tried debug mode.
    also im using RST pin sa GPIO, maybe it would have some effect.
    leo
    lowpowermcu
    Hi leo,
    Are you making these tests in standalone mode or in debug mode ?
    MCU Lüfter
