Maciej Godek
Apr 26, 2017 11:58 AM UTC
STVP fails to load \TOOLS.CNF
Posted on April 26, 2017 at 13:58
I've been trying to connect my application through ST-LINK according to the
http://www.st.com/content/ccc/resource/technical/document/user_manual/90/cb/42/ef/2e/53/46/75/CD00060186.pdf/files/CD00060186.pdf/jcr:content/translations/en.CD00060186.pdf
, but when I invoke
ESelectHard('ST-LINK', 'SWIM', FALSE)
it returns 0, and
CGetLastError
provides the following message:
File \TOOLS.CNF : No such file or directory
The file TOOLS.CNF is clearly present in the same directory as the .dll files that I successfully manage to load (eprcore60.dll, dbca60.dll, lef60.dll and file60.dll).
What is the policy of s
    Maciej Godek
    Apr 26, 2017 12:02 PM UTC
    Posted on April 26, 2017 at 14:02
    I accidentally sent the incomplete question and can't find a way to edit it.
    I wanted to ask, what is the policy of searching for the .cnf files in the file60.dll -- are the paths hard coded, or are they relative to the dll files, or can their path be set somehow?
    I enclose the complete source code of my attempts below:
    #include 'stdafx.h'
    #include <windows.h>
    #include <conio.h>
    #ifndef MAX_PATH
    #define MAX_PATH 260
    #endif // MAX_PATH
    using namespace std;
    #define WARN(msg, ...) fprintf(stderr, msg '\n', ## __VA_ARGS__)
    #define WWARN(wmsg, ...) fwprintf(stderr, wmsg L'\n', ## __VA_ARGS__)
    typedef int(*EAllAccess_t)(DWORD dwAreaId);
    typedef int(*EAreaAccess_t)(DWORD dwAreaId, long FirstAddr, long LastAddr);
    int(*ESelectDevice)(const char *szDevice);
    int (*ESelectHard)(const char *szCard, const char *szProtocol, BOOL bDemo);
    int(*ESelectPort)(const char *szPort);
    int(*ESetPreferences)(int iPreference, BOOL bState);
    int(*ESetProtection)(const char *szProtectMode, BOOL bState);
    int(*ECheckSum)(DWORD dwAreaId, long *FileCheckSum, long *MemoryCheckSum);
    int (*EGetId)(const char *szName, DWORD *pdwId);
    char *(*EGetImagePtr)(DWORD dwAreaId, long *MemSize);
    int(*ECloseComm)();
    char *(*CGetLastError)() = NULL;
    char *LastErrorMessage()
        if (CGetLastError)
            return CGetLastError();
        return 'unknown error';
    #define TRY(action) if(!(action)) { WARN(# action ' failed: %s', LastErrorMessage()); return; }
    EAllAccess_t EBlankAll;
    EAreaAccess_t EBlankArea;
    EAllAccess_t EEraseAll;
    EAreaAccess_t EEraseArea;
    EAllAccess_t EProgAll;
    EAreaAccess_t EProgArea;
    //EAllAccess_t EReadAll;
    EAreaAccess_t EReadArea;
    EAllAccess_t EVerifyAll;
    EAreaAccess_t EVerifyArea;
    void LoadLibraries()
        HINSTANCE eprcore, dbca, lef, file;
        TRY(eprcore = LoadLibrary(L'eprcore60.dll'));
        TRY(dbca = LoadLibrary(L'dbca60.dll'));
        TRY(lef = LoadLibrary(L'lef60.dll'));
        TRY(file = LoadLibrary(L'file60.dll'));
        TRY(CGetLastError = (char *(*)()) GetProcAddress(dbca, 'CGetLastError'));
        TRY(ESelectPort = (int(*)(const char *))GetProcAddress(eprcore, 'ESelectPort'));
        //TRY(EReadAll = (EAllAccess_t)GetProcAddress(eprcore, 'EReadAll'));
        TRY(ESelectHard = (int(*)(const char *, const char *, BOOL)) GetProcAddress(eprcore, 'ESelectHard'));
        TRY(EReadArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EReadArea'));
        TRY(EVerifyAll = (EAllAccess_t)GetProcAddress(eprcore, 'EVerifyAll'));
        TRY(EVerifyArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EVerifyArea'));
        TRY(EProgAll = (EAllAccess_t)GetProcAddress(eprcore, 'EProgAll'));
        TRY(EProgArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EProgArea'));
        TRY(EEraseAll = (EAllAccess_t)GetProcAddress(eprcore, 'EEraseAll'));
        TRY(EEraseArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EEraseArea'));
        TRY(EBlankAll = (EAllAccess_t)GetProcAddress(eprcore, 'EBlankAll'));
        TRY(EBlankArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EBlankArea'));
    void ReadMemory()
        DWORD PROGRAM_MEMORY, DATA_MEMORY;
        TRY(ESelectHard('ST-LINK', 'SWIM', FALSE));
        TRY(ESelectDevice('STM8L15xC6'));
        TRY(ESelectPort('USB'));
        TRY(EGetId('PROGRAM MEMORY', &PROGRAM_MEMORY));
        TRY(EGetId('DATA MEMORY', &DATA_MEMORY));
        WARN('PROGRAM MEMORY = %d, DATA MEMORY = %d', PROGRAM_MEMORY, DATA_MEMORY);
    int main()
        TCHAR pwd[MAX_PATH];
        _wgetcwd(pwd, MAX_PATH);
        WWARN(L'Current Working Directory: %s\n', pwd);
        SetDllDirectory(L'C:\\st_toolset\\stvp');
        LoadLibraries();
        ReadMemory();
        getchar();
        return 0;
    Maciej Godek
    Apr 26, 2017 2:19 PM UTC
    Posted on April 26, 2017 at 16:19
    I managed to solve the problem by invoking the 'CSetWorkingDir' function. Sorry for the noise.
