nik
Jan 29, 2007 2:46 PM UTC
Stuck in Startup Code (STR912FW44)
Posted on January 29, 2007 at 15:46
nik
nikAuthor
May 17, 2011 7:35 AM UTC
Posted on May 17, 2011 at 09:35
I am starting to get into uC programming with the Keil MCBSTR9. First step was to rewrite their example Blinky using the ST Software Lib. Compiling, linking worked and so did uploading.
But nothing is happening on the board. So I tried to debug. For some reasons the debugger gets stuck in the Startup file... Any hints?
Help appreciated.
Cheers
Nik
nik
nikAuthor
thanks for the reply. Must have been some kind of a bug in the Keil software or in my setup (I am running the uVision in VMWare under Linux). Now it is working.
Cheers
Nik
