adaszeq
Feb 24, 2013 8:08 AM UTC
Strange value of register
Posted on February 24, 2013 at 09:08
I have one strange problem. After this fragment of code program:
b = a;
a =/ 40;
if(!a)
//breakpoints
the results of two registers are: b = 50000 - good value,
a=0
The value of a should be about 1250 not 0!!
I can't find place in my program where i change value of a, because I use it only in one place.
Any suggestion how can I find solutions of this problem?
#incorrect-expectations #wrong-value-register-bug #optimisation
    Andrew Neil
    Feb 25, 2013 9:07 AM UTC
    Posted on February 25, 2013 at 10:07
    You have not given enough information.
    Post the smallest complete  program which illustrates your problem...
    luca239955_stm1_st
    Feb 26, 2013 8:03 AM UTC
    Posted on February 26, 2013 at 09:03
    most likely something has been optimized away: first step is to declare the variables as volatile and see if you get the expected value.
    Andrew Neil
    Feb 26, 2013 6:46 PM UTC
    Posted on February 26, 2013 at 19:46
    ''declare the variables as volatile and see if you get the expected value''
    If you do, that may well be an indication that the expectation  was flawed...
    http://bit.ly/Vv8fFg
    richhamersley
    Mar 4, 2013 4:16 PM UTC
    Posted on March 04, 2013 at 17:16
    Did you mean:  a /= 40;
    i.e., a = a/40;
    instead of a =/40?
    a =/ 40;  if accepted by compiler will always set a to 0.
