halim
May 17, 2011 7:31 AM UTC
Posted on May 17, 2011 at 09:31
Hi
you are right.
This issue was fixed in the next Rev of LIb.
with best regards
Punto
stefano239955_stm1_stmicro
in the UART libs the UART_ClearITPendingBit()
fuction has the following code :
/* Clear the specified interrupt */
UARTx->ICR &= UART_IT;
This code in my eval board give me unpredictable results :( !!!
The ICR register is write only.
To clear the IT bit is sufficient to write
UARTx->ICR = UART_IT;
alain239955_st
Sorry but the library available NOW on St web site still implement :
void UART_ClearITPendingBit(UART_TypeDef* UARTx, u16 UART_IT)
:-Y
Mister StMicro please update your sources !
