nivelin
Jun 27, 2008 8:05 AM UTC
STR912FAW44 Revision H and U-LINK issue
Posted on June 27, 2008 at 10:05
nivelin
nivelinAuthor
May 17, 2011 7:53 AM UTC
Posted on May 17, 2011 at 09:53
Hi Guys,
We have started using a hardware design with STR912FAW44 (Revision H) CPU.
We are experiencing problems to use MDK-ARM of Keil and U-lINK as a JTAG for debugging.
The following message occurs: Memory missmatch
Address: 0x00008000
Value: =0x04
Expected: = 0x38
No problems to erase / program / verify.
Are anyone using already this revision H and have the same issue?
Thanks a lot in advance,
Boomer
kaleduseniopastas
I am having the same problem, has anyone found a solution for this?
Thanks,
Julius
jilisegiar
try to download your code using the download button(Flash-> Download) then start the debug session(Debug-> satrt\stop debug session)
nivelin
nivelinAuthor
Yep, I was able to overcome it.
Just uncheck “Verify Code Download�? option. in Debug -> Settings..
Another way, suggested by ST, is to uncheck “Use Reset at Startup�?.
Both work.
