pvanc9
Feb 1, 2007 12:17 PM UTC
STR912 PWM on-the-fly modification of the duty cycle
Posted on February 01, 2007 at 13:17
pvanc9
pvanc9Author
May 17, 2011 7:36 AM UTC
Posted on May 17, 2011 at 09:36
Who can cleanly play with PWM,please help me.On my sinewaveform is ugly spike. /only on downward part /
I write directly to pwm register TIM3_OC1R = signal16;
I think I do not want interrupt on pwm.
TIM3_OC1R = 0x000001FC;//ini signal
TIM3_OC2R = 0x00000400;//PWM period
TIM3_CNTR = 0x00000000;//ini count
TIM3_CR2 = 0x00000000;//prescaler 00
TIM3_CR1 = 0x00008150;
Thanks for your help.
mark9
See page 133 of the reference manual. It has this footnote:
When Counter = OC2R, then OCF2 bit will be set. This can generate an interrupt if OC2IE is
set. This interrupt will help any application where pulse-width or period needs to be changed
interactively.
