slanglois
Apr 17, 2008 9:53 AM UTC
STR9 Reset Himself during UART transmission
Posted on April 17, 2008 at 11:53
slanglois
slangloisAuthor
May 17, 2011 7:52 AM UTC
Posted on May 17, 2011 at 09:52
Yes, it's sure that I have watch some exemple. The UART used to work properly. What can make the CPU resets?
kais
have you tried to use the UART example delivered with STR9 software library available in ST web site, may be you have a software pb?
Regards,
slanglois
slangloisAuthor
When tranmiting packet RX (From PC) and TX (To PC), after a moment (random), the CPU resets. I don't use the Watchdog. This happens either on the STR912FAW44X6 and 47X6. This is not a desired feature. What can happen there? Thanks
slanglois
slangloisAuthor
It reset during the TX (the last packet before the reset is incomplete).
