mail13
Jan 25, 2008 7:24 AM UTC
STR751 ADC and Power Supply Question
Posted on January 25, 2008 at 08:24
mail13
mail13Author
Jan 25, 2008 6:05 AM UTC
Posted on January 25, 2008 at 07:05
I need some help to understand the datasheet of the STR751 ARM, because some sentences are very unclear:
There is said that the VDDA_ADC and VSSA_ADC pins are the analog power supply of the A/D converter cell, but how can I set the reference-Voltage? I need 0-5V Measurement.
There is a chapter named ''Power supply schemes'' but there is nothing said about the STR751-µC -> Does it work with 5V?
Can I set VDDA_ADC higher than VDD_IO?
Why is USB disabled in 5V-Mode?
jgoril
Reference manual says that VDDA_ADC must be equal to VDD_IO. Since it is ''sensitive'' supply, you can use better filtering for this pin. That's all...
I'm in doubt whether you will find any answer for your second question - Why is USB disable in 5V mode...
