xaviooo
Jun 7, 2007 3:08 AM UTC
STR750 and long long 64 bits
Posted on June 07, 2007 at 05:08
xaviooo
xavioooAuthor
Jun 6, 2007 12:41 PM UTC
Posted on June 06, 2007 at 14:41
My question is simple.
Does the STR750 support this :
typedef long long u64 ?
I'm trying to do this :
u32 a;
u32 b;
long long c ;
c = (u32)a * (u32)b;
but it dosen't work...
Thank you for your help.
-Xavier
I'm trying to
[ This message was edited by: Xavio on 07-06-2007 08:32 ]
sjo
Jun 6, 2007 2:47 PM UTC
Posted on June 06, 2007 at 16:47
This is down to to compiler not the device, works fine on all the tools i have tried.
What tools are you using ?
It would not help that you are casting your result to 32bits.
sjo
kleshov
Jun 7, 2007 1:39 AM UTC
Posted on June 07, 2007 at 03:39
I think what you are trying to do is this:
u32 a, b;
u64 c;
c = (u64)a * (u64)b;
In C, it is assumed that the result of u32*u32 is u32, unless you tell the compiler otherwise.
- mike
xaviooo
xavioooAuthor
Thank you so much for your answers, it works.
