ralf23
Oct 20, 2005 6:16 AM UTC
STR71x ADC Resolution/Accuracy
Posted on October 20, 2005 at 08:16
ralf23
ralf23Author
Oct 20, 2005 5:51 AM UTC
Posted on October 20, 2005 at 07:51
Hello Forum,
Revision 6 of the STR71xF Datasheet specifies the ADC with a resolution of typ. 12 bits on page 43/49.
Revision 6 of the STR71x Microcontroller Reference Manual says in a Note on page 331/345 ''Only the 11 most significant bits out of these 16 bits (of the ADC_DAT[n] registers) are guaranteed to be accurate according to the device specification, even if all the 16 bits can be read.''
I find this very confusing. Could you please clarify on the ADC resolution and errors ?
Thank you very much.
Ralf
hichem2
Hi Vader,
The STR71x ADC have a 12 bit of resolution, this info will be corrected in Rev 7.
Cheers,
Hich
