klavdijo
May 10, 2007 6:31 AM UTC
STR710FZ2 and JTAG
Posted on May 10, 2007 at 08:31
STR710FZ2 and JTAG
klavdijo
klavdijoAuthor
May 9, 2007 2:05 AM UTC
Posted on May 09, 2007 at 04:05
Hello!
We made our own proto bord on the shenmatic example of ST AN1775. We used HITEX Tantino 7-9 JTAG and IDE enviroment. At the first everithing was communicating ok but at one time after 3 days of SW developtment on protobord the communication with JTAG was lost and can't be established any more. The same problem was on HITEX prototype board. We solved the problem with BOOT pins but I want to know what is the cause of that problem and how to fix it. The problem was described on KEIL internet page too.
Thank you!
gfr
May 9, 2007 10:52 AM UTC
Posted on May 09, 2007 at 12:52
Hello
We made our own proto bord too and we have problems with JTAG communication, so can you explain what you did with BOOT pins to solve your problem ? And can you give the link of the KEIL internet page where the problem is described ?
Thanks in advance
klavdijo
klavdijoAuthor
http://www.keil.com/support/docs/3001.htm
Hello !
Here you have a link to KEIL. I belive you will get the answer.
By!
