ezanen9
Nov 24, 2005 3:07 AM UTC
STR710 writing to it's own flash memory
Posted on November 24, 2005 at 04:07
ezanen9
ezanen9Author
Nov 7, 2005 4:20 AM UTC
Posted on November 07, 2005 at 05:20
Hi all,
I have to write a few calibration values to non volatile memory. The calibartion values come from a routine that in only called once after installation of the device. These values have to be available after a reboot of the microcontroller.
Is it possible that the str710 microcontroller writes for example integer values to it's own flash memory?
Regards,
Jimmey
ben2
Nov 7, 2005 6:03 AM UTC
Posted on November 07, 2005 at 07:03
You can use Bank 1(16k) for this purpose. I think there have been some examples posted on here, if you do a search.
ezanen9
ezanen9Author
Hi, thanks for your answer.
How does it look when I want to write a few integers variables to the flash in C code? Do I have to allocate memory or can I write to a specific adress directly?
Regards,
Jimmey
