spektrum_ada
Jun 16, 2005 11:43 AM UTC
Posted on June 16, 2005 at 13:43
I have STR710-EVAL board and IAR Embedded Workbench for software development. I could compile the files in IAR embedded workbench. Now in order to download the code to STR710-EVAL which debugger should I use?
I have a emulator (JTAG Pod) form Nohau and Sehau debugger. Can I use this? But there is no selection in IAR EW IDE for this
Please let me know
shuk
spektrum_ada
Jun 20, 2005 2:22 AM UTC
Posted on June 20, 2005 at 04:22
Thanks for the reply
Whether can I use RVDK (with micro ICE) from ST Micro? If so, which option I should select in the IAR Embedded Workbench? (for debugger)
Thanks in advance
shuk
