NZama.1
Storing variables in standby mode
Can anyone please help me with this problem. I want to store some values while the processor is in Standby mode. As, when it wakes up all the variables are reset. How can i make the variables static in case of standby mode. Any help will be appreciated. Thank you.
Javier1
Principal
February 15, 2023
which processor?
hit me up in https://www.linkedin.com/in/javiermuñoz/
NZama.1
NZama.1Author
It's STM32F407VGT6 Discovery board
MM..1
STANDBY mode is only ended by aka reset MCU , then your code reinit all, but you can read about RTC backup registers ... This way only under power MCU hold values.
If you need store somethink after power lost , you need EEPROM external or emulated in flash...
