giovanni239955
Aug 5, 2003 6:44 AM UTC
Stop mode with WFI
Posted on August 05, 2003 at 08:44
Stop mode with WFI
romain2399
May 17, 2011 9:34 AM UTC
Posted on May 17, 2011 at 11:34
Have a look to the attached project.
giovanni239955
We are using ST92F150.
Can you provide to me a software example how to enter and leave Stop Mode?
giovanni239955
In ST92F150, it's written: << to enter STOP Mode, write the sequence 1,0,1 to Stop bit with three consecutive write operations. >>
But the instructions:
WU_CTLR |= WUm_stop;
WU_CTLR &= ~WUm_stop;
in the .lis file, are assemblied in this way:
or @WU_CTLR,#4
ld r0,@WU_CTLR
ld @WU_CTLR,r0
and @WU_CTLR,#251
ld r0,@WU_CTLR
ld @WU_CTLR,r0
or @WU_CTLR,#4
ld r0,@WU_CTLR
ld @WU_CTLR,r0
Having not consecutive 3 write instructions could be a problem ?
Thanks a lot
giovanni239955
Thanks Romain.
I would be very grateful if you coul help me to understand why I don't enter Stop mode.
Here attached the Low_power() function and other definitions. During normal functioning, ADC interrupt and STIM interrupt are working.
I'm not able to enter stop mode (STA_DBG always equal to 3).
I'm not interested in manage wake-up interrupt, I only need to wake up and restart.
Do you see an evident error?
Thanks a lot
kapil
Yes these extra instructions generated can cause problem.
They can be removed by increasing the level of optimization.
giovanni239955
Thanks.
I already tried with optimization compilation and now works fine!
