Kmax18
Senior II
March 26, 2023
STM8S105C4T6, inverting the UART2_TX signal
I need an active high UART signal. Yes, the STM8S UART2_TX signal is active, but for hardware reasons I must invert the active low PCB output (UART2_TX). An easy solution would be a programmable STM8S feature to invert the signal. The reference manual does not list that option. Is that correct?
Thank you for your response.
    Peter BENSCH
    Peter BENSCHBest answer
    Correct, unlike STM32, STM8 has no feature to invert UART TX.
    Does it answer your question?
    /Peter
    Peter BENSCH
    /Peter
    Kmax18
    Kmax18Author
    Senior II
    March 26, 2023
    Thank you. Yes, that answers my question.
    Peter BENSCH
    Great! I hope you find a way to invert the signal externally.
    If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
    Good luck!
    /Peter
