shtoh
Oct 28, 2010 8:34 AM UTC
STM8S105 Interrupt Execution Time (using Raisonance Ride 7)
Posted on October 28, 2010 at 10:34
    lowpowermcu
    May 17, 2011 1:11 PM UTC
    Posted on May 17, 2011 at 15:11
    Hi toh.seng_huat,
    why you don't use TIM1 in PWM mode ?
    You can run timer counter in 1ms (as example) and channel 1 in pwm: ARR = 3000 and CCR1 = 2000 and you will get your signal without caring about it in software. Your CPU will be loaded-off.
    MCU Lüfetr
    shtoh
    shtohAuthor
    Hi lowpowermcu,
    Actually, i'm testing on a pre-designed pcb circuit, so my timer 1 does not connect to any LEDs, only timer3 does. That's why i'm using timer3.
    Understands that setting CCR to the ratio of the ARR can get the desired outcome... As i need to show that I can use PWM mode to make the LED glow and off.
    Currently I manage to get the effect on and going.
    Thanks a lot.
    Hi toh.seng_huat,
    MCU Lüfetr
