adriano2
Oct 8, 2009 11:09 AM UTC
STM8S103 problem with ++
Posted on October 08, 2009 at 13:09
    adriano2
    adriano2Author
    May 17, 2011 1:05 PM UTC
    Posted on May 17, 2011 at 15:05
    I solved and the problem is the STVD IDE, in fact I had the HS_Values_X[uC++] term in the Watch. By removing it from the watch all work.
    For some strange reason the Watch modify the variable :-Y
    thanks
    mozra27
    Hi Genius,
    The uC variable should be declaration as volatile... thanks to check this point.
    mozra
    adriano2
    adriano2Author
    Dear All
    I have a too strange behaviour with the following code:
    while (HS_Values_X[uC++] < Conversion_Values[0]);
    HallAngle[0] = HS_ANGLE_X[uC-1];
    In fact, by following the code step by step with the debugger uC variable increase three by three any step (and not by one).
    I changed the firwmare:
    while (HS_Values_X[uC] < Conversion_Values[0])
    uC++;
    but I obtain the same strange behaviour. Why?
    Some one could help me!?! I have set the compiler in order to minimize the code size.
