dexter_khm
May 8, 2015 1:44 PM UTC
STM8S003k3 TIM1 PWM problem
Posted on May 08, 2015 at 15:44
Hello every one. I have a workable code of pwm on STM8S105K4T6 and now I paste it in STM8S003k3 fnd it won't work.
&sharpdefine CCR1_Val  ((u16)2047) // Configure channel 1 Pulse Width Blue
&sharpdefine CCR2_Val  ((u16)2047) // Configure channel 2 Pulse Width
static void TIM1_Config(void)
   TIM1_DeInit();
  /* Time Base configuration */
  TIM1_Period = 4095
  TIM1_Prescaler = 0
  TIM1_CounterMode = TIM1_COUNTERMODE_UP
  TIM1_RepetitionCounter = 0
  TIM1_TimeBaseInit(0, TIM1_COUNTERMODE_UP, 4095, 0);
  /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  TIM1_OCMode = TIM1_OCMODE_PWM2
  TIM1_OutputState = TIM1_OUTPUTSTATE_ENABLE
  TIM1_OutputNState = TIM1_OUTPUTNSTATE_ENABLE
  TIM1_Pulse = CCR1_Val
  TIM1_OCPolarity = TIM1_OCPOLARITY_LOW
  TIM1_OCNPolarity = TIM1_OCNPOLARITY_HIGH
  TIM1_OCIdleState = TIM1_OCIDLESTATE_SET
  TIM1_OCNIdleState = TIM1_OCIDLESTATE_RESET
  /*TIM1_Pulse = CCR2_Val*/
  TIM1_OC2Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE, CCR2_Val,
               TIM1_OCPOLARITY_LOW, TIM1_OCNPOLARITY_HIGH, TIM1_OCIDLESTATE_SET,
               TIM1_OCNIDLESTATE_RESET);
  /*TIM1_Pulse = CCR4_Val*/
  TIM1_OC4Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, CCR1_Val, TIM1_OCPOLARITY_LOW,
               TIM1_OCIDLESTATE_SET);
  /* TIM1 counter enable */
  TIM1_Cmd(ENABLE);
  /* TIM1 Main Output Enable */
  TIM1_CtrlPWMOutputs(ENABLE);
Can any one tell me what is wrong here.
#stm8s003k3-tim1-pwm-problem
dexter_khm
May 8, 2015 6:26 PM UTC
Posted on May 08, 2015 at 20:26
Sorry my fault code is fine. I just forget remap Timer 1 -channel 4[AFR6] where my status led is
