STM8S003F3 Datasheet pin description
I'm just starting to learn about MCUs and am reviewing the datasheet for the STM8S003F3. In the pin description table, I came across some symbols that I'm not quite sure about, such as bold X with underline (X), regular X (X), and dash (-). What do these symbols mean?
    TDKBest answer
    March 18, 2025
    dash is not available or not applicable.
    X is supported.
    bold X with underline is the pin state after reset
    TDKBest answer
    March 18, 2025
    X is supported.
    zin10Author
    Thank you
    CustomSarge
    A quick heads up:
    Other mfgrs retain pin->function assignments.
    ST Ports will still be ports, but "other" functions DO change with the package.
    I got the "wake up" on an STM8S003 TSSOP-20 VS QFP-32.
    If you're going to proto in a different package, keep it in mind.  <<<)))
    zin10Author
    Thank you!
