bala21ece
Jun 2, 2016 10:44 AM UTC
stm8s003 ic
Posted on June 02, 2016 at 12:44
I'm trying to use the ST Visual Develop with the Cosmic st8 32k compiler.  I install everything and build the project.  That all works fine.  When I try to connect to the Discovery board with the debugger using Swim ST-link, I receive the following error:
Failed to connect target.
Starting debug session...
 -> Emulator reset (usb://usb)...
  ** Connection error (usb://usb): swim error [30200]: st-link connection error
 -> Failed to connect target.
