ra.kadyrov9
Oct 13, 2010 6:42 AM UTC
stm8s TIM1’s One Pulse Mode problem
Posted on October 13, 2010 at 08:42
    ra.kadyrov9
    May 17, 2011 1:10 PM UTC
    Posted on May 17, 2011 at 15:10
    Oh, problem is solved! Thanks lowpowermcu!
    TIM1->EGR is set to 0x01 in TIM1_DeInit(), but then it is disabled in TIM1_OC1Init() for some reason. I set it by TIM1_GenerateEvent(TIM1_EVENTSOURCE_UPDATE) again and now Update Event occurs at the right moment. Here is fixed code:
    TIM1_DeInit();
    TIM1_TimeBaseInit(0, TIM1_COUNTERMODE_UP, 0xFF, 10);
    TIM1_OC1Init(TIM1_OCMODE_PWM1, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_DISABLE, 0x7F, TIM1_OCPOLARITY_LOW, TIM1_OCNPOLARITY_LOW, TIM1_OCIDLESTATE_RESET, TIM1_OCNIDLESTATE_RESET);
    TIM1_SelectOnePulseMode(TIM1_OPMODE_SINGLE);
    TIM1_GenerateEvent(TIM1_EVENTSOURCE_UPDATE);
    TIM1_CtrlPWMOutputs(ENABLE);
    TIM1_Cmd(ENABLE);
    Hi kadyrov,
    Try to generate an update event before enabling counter. Hope that solves.
    TIM1_DeInit();
    /* generate update event */
    TIM1->EGR |= 0x01; /* or something like that */
    TIM1_Cmd(ENABLE);
    Tell me if it is OK.
    Regards,
    MCU Lüfter
    lowpowermcu
    Hi kadyrov,
    TIM1_DeInit();
    TIM1_Cmd(ENABLE);
    Regards,
    MCU Lüfter
