klaasdc
Oct 16, 2010 4:09 PM UTC
STM8S PWM jitter
Posted on October 16, 2010 at 18:09
STM8S PWM jitter
    klaasdc
    klaasdcAuthor
    May 17, 2011 1:11 PM UTC
    Posted on May 17, 2011 at 15:11
    Hi lowpowermcu,
    You understand the code correctly. I'm implementing a digital tachometer that controls an analog needle attached to a servo.
    The suggestion you made is a very good idea. I had not considered that before. I will try it now :)
    However, I'm still a bit worried by the fact that I can consistenly make the next timer's output a rubbish value by calling TIMx_SetCounter(0) at a certain frequency. I'm beginning to fear it might be some sort of bug. When I have some time I might verify this with a pulse generator as I can't believe it.
    lowpowermcu
    Hi klaas,
    Felicitation !!!
    regards,
    MCU Lüfter
